How to Convert DVD to Blu-ray with DVDFab DVD to Blu-ray Converter?
06/15/2023
DVDFab DVD to Blu-ray Converter can merge and convert multiple DVDs into one Blu-ray for an easy playback or a neat backup. It’s very simple to do this DVD to Blu-ray conversion, in just a few of steps.
Step 1: Run DVD to Blu-ray Converter
Run DVDFab 12, go to Copy module and click the default mode icon on the top left corner to bring about all supported copy modes. Choose “To Blu-ray” to activate the DVD to Blu-ray Converter.
Step 2: Load the DVDs
Load your DVD digital source by clicking the Add button on the main interface. Or drag the DVD files into the program. If you want to load physical DVD discs directly, please make sure you have the corresponding number of DVD drives connected to your computer according to how many DVDs you want to convert. Then insert these discs into the drives for DVDFab to load them.
Step 3: Customize your own videos
After they’re in, you are free to change their chapters, audio tracks and subtitles and make advanced settings according to your needs. On “Advanced Settings” panel, you can decide the output as BD 50 or BD 25 and customize the Blu-ray menu by clicking Custom Menu. If you want no menu, selecting “No Menu” in the Menu Mode will do.
Step 4: Select an output dictionary
Navigate to the bottom of the main interface to select a directory to save the output DVD: to select your optical drive as the directory from the drop-down list box is to save the output to a blank disc; to select a directory by clicking the "Folder" icon is to save the output as a DVD folder on your hard drive; to select a directory by clicking the "Image" icon is to save the output as an ISO image file on your hard drive.
Step 5: Start the conversion process
Click the "Start" button to start the process of DVD to Blu-ray conversion.
Please refer to DVDFab DVD to Blu-ray Converter for more information.
① Convert & upscale DVDs to standard Blu-rays with premium quality
② Burn the output Blu-rays to blank discs or save as ISO files/folders
③ Support all types of blank discs: BD-R, BD-RE, DVD±R and DVD±RW
④ Offer multiple sets of beautifully crafted menu templates
